Author Topic: Price Check - 03 TJ 4.0  (Read 1134 times)
Offline Evil-jeep79
« on: April 15, 2021, 08:05:19 PM »
Well been a while since I have been on here, as I have been up in the Cold Lake area for a few years.
I have decided that it's time to let the jeep go, as I haven't been into it as much as I used to around Calgary. Problem is I have no Idea what the hell it's worth and am looking for a bit of direction.
So here is the bad..... Blew the motor last year, she will turn over and start, hell can even drive it down the street, but she knocks like you wouldn't believe. Haven't even bothered to pull the heads to see how bad it is.
The good.
03, 125ish km
2 door TJ,
transmission is good, transfer case is good.
3inch lift.... rough country- so maybe not the best, but it has low kms on the lift
Front Dis-connects
G2 44axles front and rear 4:56 gears, and air lockers front and back w the 33cromoly axles, and rear disc brake conversion..... less than 500km on them
Brand new 35 Maxxis Crawler LT, 35x12.5x15 on steel rims
Body is good, no dents slight surface rust on door hinges and window hinges.
Front right fender has slight dent from high-lift jack catching it while mounted.
No carpets, but interior is in good shape, no damage
Custom truck back, that comes off with three bolts each side, full roll cage is still intact, soft top is chopped and needs to be replaced
Motormaster 10000lb winch on Heavy duty custom bumper, only pulled once
200amp alternator
new water pump
I am sure there is a few things I forgot but that is the majority of it.
I was thinking of just scrapping it but figured that it might be a good start into someone that just wants to swap a junk yard 4.0l into and hit some trails.
Any help on suggested price hugely appreciated, if you are for some reason interested in hauling a trailer this far north let me know and I can send pics.
Thanks all
Offline The Machinist
  • I’m with stupid!
Re: Price Check - 03 TJ 4.0
« Reply #1 on: April 18, 2021, 08:44:07 AM »
Hi, I’d be interested in buying this from you.  If you want to send me some pictures maybe we can work something out?
Jamey
403-617-8671
« Reply #2 on: April 18, 2021, 09:16:48 PM »
Bad Jamey!
Or is this for the wife?
Offline Milan
« Reply #3 on: May 02, 2021, 08:00:28 PM »
I think this might be Jamey's stroker project.
Keep on Jeepin'
Offline rws
  • Stump Grinder
« Reply #4 on: May 03, 2021, 07:30:40 AM »
Yes?  A little subliminal pressure :) :)
  • I’m with stupid!
« Reply #5 on: May 03, 2021, 08:51:36 PM »
Haha, no such luck!  Need to finish the first one!
