Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Radiator Fan running steady
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Radiator Fan running steady (Read 865 times)
Jason Walker
Stocker
on:
June 23, 2023, 10:14:46 PM »
So haven’t been on here in a while but in need of some help. Coolant temp is running between 107 and 122C. Fan turns on and runs constantly. Had water pump replaced as it had a hole. Thermostat was replaced. Coolant temp sensor replaced. Took to shop and they had said needs a new radiator fan as it was only running on high. Replaced the fan $$$$. Have cleaned the radiator. Fan runs steady until I turn the Jeep off. Coolant Temp while driving at 100km/hr gets up. Can’t even go through a drive through as cannot hear them due to fan not stopping.
Looking for any advice for next steps because it is draining me of $$$.
Logged
J-Dub
fug
CJA Executive
Talks waaay too much!
Airdrie Pick n Pull
Re: Radiator Fan running steady
Reply #1 on:
July 03, 2023, 05:38:29 PM »
What model Jeep are we talking about here?
Fan will run if your AC is on so that might be something to try (turn AC off see if that changes things). Also maybe check the fan relay... its possible its failed on.
Logged
Fug
TJ Rubicon
Zooguy
Baby Wheeler
83 CJ7- AMC 360
Reply #2 on:
July 04, 2023, 12:50:07 PM »
Hey Jason, I think I might have found my issue. ( Fan not cooling enough)
I will likely cancel my appointment with Calgary radiator in the 12th. Not sure if you want that appointment or not. Let me know.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
