Author Topic: cherokee stalling  (Read 1006 times)
Offline chrysler
cherokee stalling
« on: August 20, 2006, 08:22:18 PM »
ok heres the deal i got a 94 xj 4.0 HO i was getting ready to go wheeling last week and as i was leaving my house it started stalling everytime i gave it gass thought it was maybe the fuel pump at first but when i checked the pressure it was runing 35 to 40 psi so after looking at my haynes manual :violin: i tried checking the code and it came up crank position sensor , throttle position sensor , and manifold air temperature sensor. so after talking with some mechanics they said it was likely the first sensor (crank positioning) that was causing the stall and seting off the codes for the other 2 sensors so i replaced the crank positioning sensor and the truck drove fine for 2 days then last night i went weeling that involved a bit of water and all of a sudden my stalling problem is back again however it isnt as severe as before where before i couldnt get 5 feet without stalling now it only does it every few kilometers or so and it gets worse when it heats up any ideas or has any one ever had this problem before please post any suggestions  i would greatly apreciate it thanks  :sign13:
Any body got a winch???
