Author Topic: spring perches  (Read 1563 times)
bubba
spring perches
« on: August 21, 2006, 01:51:25 PM »
I am wondering if you can buy-or is it advised to use bolt on spring perches-want to do an axle swap-but cannot weld-I have friends that can...but I am just wondering if they are available to buy...thx
Becker
spring perches
« Reply #1 on: August 21, 2006, 04:05:10 PM »
I don't believe you can.  I think it would become an issue of them "slipping/twisting" under load.
When I did my spring over I went to Standens and bought new perches there and had them welded to the axle.
Just my thoughts
JeepInMud
spring perches
« Reply #2 on: August 21, 2006, 04:41:38 PM »
I bought a set of spring perches that were the weld on style and then torqued them down with my u-bolts and then once I was happy with the pinion angle, I had them welded in.
bubba
spring perches
« Reply #3 on: August 21, 2006, 05:05:23 PM »
Yeh thats kinda what I was thinking-if I could get everything the way I wanted them to sit-the get the welded somewhere...thx for the replies...think I will do what JeepInMud said.....thx
unionjack
spring over axle?
« Reply #4 on: August 28, 2006, 05:24:09 PM »
just wondering how much it cost to do the leaf over axle, my only prob is im running dana 60's and the front diff has gussets or whatever on the top making it difficult to locate spring mount on top!!!!!!!!!!any suggestions?
Offline SPOT
Re: spring over axle?
« Reply #5 on: August 28, 2006, 09:39:03 PM »
Quote from: "unionjack"
you will also have to make your frame a 1/2 inch a side wider to fit the 60
unionjack
ouch
« Reply #6 on: August 29, 2006, 02:42:43 PM »
well leaving it the way it is ...............is sounding better and better
