Author Topic: lights won't go out  (Read 1078 times)
Offline rossb
lights won't go out
« on: August 25, 2006, 02:03:19 PM »
I have a 2002 TJ.  Just this week I was driving it and now the lights won't go off, even without the key in it.  Also the high beam indicator is on solidly whenever it is running.  I have been towing the jeep quite a bit behind the MH but there are separately wired lights for use when towing.  Anyone ever have a problem like this?  The only way I can get the lights to go off is to take off the battery cable or disconnect the lights.
Suggestions?
thanks
ross
lights won't go out
« Reply #1 on: August 25, 2006, 02:09:57 PM »
Check the daytime running lights module, it will probably be toast.
Offline rossb
Yup
« Reply #2 on: August 25, 2006, 03:17:19 PM »
...bingo...that is exactly what it was.  Thanks for the help.
BTW the dealer charged 152 bucks for one...makes me think that there are some criminals in the parts department :)
BTW there is a work around if you do not want to replace the module.  You can pull it out .. but the high beam indicator wont work.  This is a link that sorta explains it.  You can search to find other sites as well:
http://bb.bc4x4.com/printthread.php?s=74e71e1e28bed5b20d640b0423d1a8ca&threadid=98413
