Author Topic: Lunchbox Lockers  (Read 1231 times)
SuicidalPenguin
Lunchbox Lockers
« on: August 27, 2006, 02:56:36 PM »
I'm in the middle of putting in a Lock Right locker, but i can't get the shaft that holds the spider gears out.  I popped the cover to find no bolt, but the shaft will not budge, tried just pushing on it, tried a punch and hammer.  Is there something i left out to getting the shaft out? I can stick stuff into the bolt hole and it goes all the way through, so i don't think the PO broke the bolt and it's still in there.
Oh yeah, it's the D35 c-clip diff
Mac13
Lunchbox Lockers
« Reply #1 on: August 27, 2006, 05:06:23 PM »
I just put an aussie locker in my 35 and there was a small bolt holding the pinion shaft in.  I removed it and the shaft came right out
Offline bae146
bolt
« Reply #2 on: August 27, 2006, 05:14:53 PM »
I believe it is 10 mm 12 point right?
HBZ
Lunchbox Lockers
« Reply #3 on: August 31, 2006, 05:50:29 PM »
You may have to use a punch and drive a roll pin out of the case to remove the shaft if you do not have a bolt.
Good luck.
 :D  :D
