Author Topic: TJ Dasboard speaker upgrade....  (Read 3908 times)
Jaguar
« on: September 04, 2006, 07:22:17 PM »
I hear that there is a bracket that you can install, to put bigger speakers in to replace the smaller stock ones. Does anyone have any info on this?
Thanks guys!
Michael
Offline fony3
« Reply #1 on: September 04, 2006, 11:37:47 PM »
These plates I have found on ebay and a couple shops in the states...they allow you to up in 5 1/4 inch speakers instead of 4x6s. The advantage is better sounds in the front due to a round speaker.
Here is the ebay site:
http://cgi.ebay.ca/1997-2006-Jeep-Wrangler-speaker-adapter-plates-NR_W0QQitemZ330023375980QQihZ014QQcategoryZ14932QQrdZ1QQcmdZViewItem
If you get them let me know how they work out, since i am thinking of doing the same. I was trying to find a template and make them myself, but no luck. Suppose i could make my own template.
Offline ramtuff
« Reply #2 on: September 05, 2006, 09:12:12 AM »
Killer Off Road Equipment
Jaguar
« Reply #3 on: September 05, 2006, 10:38:40 AM »
Awesome! thats exactly what I needed, thanks guys. I think i am going to try and just fab up those brackets. I think Lexan/Plexi glass should be strong enough... If I can find some scrap sheet metal, I'll prolly go that rout.
Thanks!
michael
Offline ornamental
    • http://www.webshots/users/yeungstreet
speakers
« Reply #4 on: September 05, 2006, 12:27:10 PM »
ive made my own using mdf board and also made a set using some sheet metal.  i would use the sheet metal as the mdf requires some shaving to fit properly.
just use the factory speaker for a template for the 2 holes on top and 2 holes below.  and in a few mins you'll have your very own bracket.
for added sound quality , stuff the area around and behind the speaker with a fibre fill
Offline murdajeep
Murdajeep
91 YJ 4.0L 3.0" Suspension Lift  1.25" Body Lift with Mickey Thompsons MTZ 33's and a champion winch, Ford 8.8, 4.10 Gears
Offline fony3
« Reply #6 on: December 12, 2006, 01:10:14 PM »
Did you ever get around to fabbing these brakets up. Just hoping to find out what you used and how it worked out.
Offline kenny kustom
« Reply #7 on: December 12, 2006, 01:22:45 PM »
Offline fony3
« Reply #8 on: December 12, 2006, 07:25:08 PM »
I actually have a buddy that does audio installs, and he recommended 5.25s over those small component sets.
« Reply #9 on: December 12, 2006, 07:45:44 PM »
i am a mobile electronics installer, i had the component set in my 91, and i really liked them.
Offline fony3
« Reply #10 on: December 13, 2006, 12:32:38 PM »
I'll keep that in mind! although i think I am gonna get me an awesome deal on some JL 5.25s.....
Considering you are an audio installer, do you have a sub(s). If so i would really like to see some pics of what you did with your box.
Offline dac
« Reply #11 on: December 14, 2006, 03:01:43 PM »
I put 4x6's up front, made my own brackets.  They work well.  As for a sub, I took the easy road and bought a 12" truck sub box from visions.  It fits perfect behind the back seat.
This is not 'Nam, this is wheeling.  There are rules.
triver525
« Reply #12 on: December 15, 2006, 07:21:15 AM »
I have a drawing of a bracket that I had made for my old TJ.  It allows you to use 4" speakers in the stock locations.  PM me or email me if you want a copy of it.  I have it in DWG, jpg or visio formats.
Offline fony3
« Reply #13 on: December 15, 2006, 10:54:29 AM »
Thanks for the offer, but i am gonna probably buy for fab up some for 5.25"
triver525
« Reply #14 on: December 15, 2006, 10:59:57 AM »
Check you speaker specs.  The opening required for the 5.25" speakers is probably much less than 5.25".  The brackets I made had a hole that was 118mm (or 4.65") and the stock speaker cover went back on with no problems.  In fact, my speakers may have been 5.25" after all.  I do remember that a third of the speaker was hidden behind the dash.  I also stuffed the hole area behind the speaker with wadding to allow the speaker to build up so pressure and to isolate front and rear of the driver.
