Author Topic: ARB Lockers  (Read 1031 times)
Offline Rubicon Josh
ARB Lockers
« on: September 17, 2006, 01:09:39 AM »
Hey guys. When I press my fancy locker button that comes factory installed on the rubicon (theres a dig for everyone who doesn't own a rubicon), the front will lock without any problems but the rear just keeps flashing. It doesn't feel like there is any change or that the locker is even trying to engage. Just wondering if anyone has encountered this problem before. I'm sure it could be something as simple as a fuse, or loose connection, but I haven't had a chance to check it out properly.
Josh
ARB Lockers
« Reply #1 on: September 17, 2006, 09:04:55 AM »
Are you saying it isnt engaging at all?
Start checking stuff by having some one hit the switch while you listen at the pump.
If the pump chirps for a second, then stops, you know you have air and no leaks.
If the pump runs on, you have a leak.
If the pump doesnt run on, your axle locks, but the light flashes, check the wires that go into your diff.
If a wire is torn off, the locker will engage, but the light will continue to flash.
If the pump does not run at all check you connections from the switch to the rear pump.
