Author Topic: Brake booster interchangability  (Read 1531 times)
4Play
« on: September 21, 2006, 06:15:59 PM »
Will a brake booster from a 4 banger jeep comanche work on a '89 YJ 4.2L?
evasion1
« Reply #1 on: September 21, 2006, 09:18:31 PM »
its off a 86 with a 2.8  v 6 not a 4
« Reply #2 on: September 22, 2006, 08:00:40 AM »
Probably.
You just need to check that that MC will bolt up, and that the booster is close enough to the right demensions.
There's a possibility that they are identical going from 86 to an 89.
All you can do is try.
Otherwise, jeepstuff charges under 100$ for a booster and MC combo off of YJ's.
4Play
« Reply #3 on: September 22, 2006, 05:55:22 PM »
Quote
bnine Posted: Fri Sep 22, 2006 2:00 pm    Post subject:
Probably.
Thanks bnine, I guess it doesn't hurt to try then...
4Play
« Reply #4 on: October 09, 2006, 12:39:54 AM »
Well I spent the weekend on the heep before the winter.  I did the rear main seal, valve cover gasket and tried the brake booster and that was a no go.  Got the old one off, it looked the exact same, but it was just a no go.   :evil:    What a never ending project....!    :?   Off to jeepstuff I go!
