Author Topic: winch compressor.....  (Read 3550 times)
« on: October 11, 2006, 11:08:32 AM »
Check this out...
Quote
Just flip the activator switch to compressor mode and discover the can-do attitude of the PowerPlant. Powered by a 4.6 hp motor, the PowerPlant puts out 5 cfm @ 90 psi, with a built-in air reservoir and intercooler. That translates to airing up four 35" tires from 8 psi to 35 psi in 8 minutes. Or less. And with the PowerPlant, there's no labor-intensive compressor set up: it's part of our standard winch mounting process.
Switch to winch mode and the PowerPlant turns on the latest in legendary WARN winch technology. You get the raw pulling power of our Gen II Series Wound motor, plus the proven reliability of the 3-stage planetary gear train and a newly designed contactor that's rugged and reliable. In other words, WARN to the rescue, time after time.
The PowerPlant is available in two configurations: HP for off-road vehicles for enthusiasts who demand faster line speed, and HD for heavier trucks for longer motor duty cycles.
WARN PowerPlant - unique, exclusive, patent-pending technology. Engineered and built by Warn Industries, the world leader in off-road and truck performance products.
Kewl 8)
« Reply #1 on: October 11, 2006, 11:24:45 AM »
That is pretty sweet, but when is the 8274 model coming out
Have you respooled your winch cable yet Dom?
Offline Elsifer
« Reply #2 on: October 11, 2006, 12:11:36 PM »
Cool idea, whats the cost of that bad boy winch?
VA6CPL
Jeepless....
Offline apex
« Reply #3 on: October 11, 2006, 12:55:51 PM »
that is trick!
Looks like a 9.5ti with a tumor.
not sure if i'd want to submerge it all that often though. Any idea what the line pull strength is?
Offline Elsifer
« Reply #4 on: October 11, 2006, 01:14:04 PM »
http://www.warn.com/powerplant_hp.shtml
Copied from the above webpage:
PowerPlantâ„¢ Dual Force HP
HP For Off-Road Enthusiasts and Recreational Users
Best in class on-board air, plus a winch geared to deliver the fast
line speeds serious off-roaders demand
12 CFM @ 0 psi, 5 CFM @ 90 psi air flow rating
100 psi max air pressure
9,500 lbs. maximum rated pull (single line)
Fast line speed of 26.9 feet minute (no load),
  5.2 feet per minute (at 9,500 lbs. max load)
125 feet of 5/16" wire rope
VA6CPL
Jeepless....
« Reply #5 on: October 11, 2006, 02:35:17 PM »
Quote from: "BlackYJ"
 :roll:  Maybe...
They will go at a simillar price that the 9.5 it.... around $1700 MSRP
they are sweet...  8)
« Reply #6 on: October 13, 2006, 12:09:30 PM »
Not too bad for the price I guess, $2060 at national, but it would be 10x the unit if it had a 8274 as the winch
Offline apex
« Reply #7 on: October 13, 2006, 11:19:54 PM »
$2k for a winch is f-ing stupid. There's no reason the 9.5 ti or xp is $1.7k either. Cablesmurf's got a smrt (yes... SMRT) thing going with the TMax.
