Author Topic: advise on converting a closed to an open cooling system  (Read 855 times)
Offline familyofjeeps
« on: October 20, 2006, 08:19:00 PM »
My son has a 88xj 4.0l that recently started to over heat, he has replaced the following thermostat,rad,hoses,water pump, coolant pressure bottle and water valve. Should he have converted over to a closed system - what would a disadvantge of doing the swap?
what's around the next corner?
Offline fug
  • Airdrie Pick n Pull
« Reply #1 on: October 21, 2006, 12:08:56 AM »
If he has a coolant overflow bottle wouldn't that be considered a closed system?  Not sure if I'm missing something here but I'm not sure what you're asking.
Fug
TJ Rubicon
