Author Topic: rear transfer case seal  (Read 1317 times)
« on: October 23, 2006, 10:39:14 PM »
How hard are these to replace?  Noticed a red puddle under the heep today, dripping off the back of the transfer skid plate.  :(
Offline redbull
« Reply #1 on: October 24, 2006, 01:00:00 AM »
An SYE kit would come with a new seal.....  :D
« Reply #2 on: October 24, 2006, 03:03:27 AM »
Hmmm.....how hard is the install on one of those?
Offline fony3
« Reply #3 on: October 24, 2006, 08:26:13 AM »
« Reply #4 on: October 24, 2006, 12:45:57 PM »
Where is a good place to get one of these?
« Reply #5 on: October 24, 2006, 08:29:07 PM »
Hmmm....leak appears to be coming from the gasket seal in between the halves of the case.
No way to crack and reseal this without taking the case off, is there?
Offline calltrex
« Reply #6 on: October 24, 2006, 09:22:16 PM »
no gasket between. just split it apart and rtv back together.
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
« Reply #7 on: October 24, 2006, 10:22:34 PM »
Quote from: "dunl"
You can do it with out pulling the case, but its a lot harder cleaning, working on, and reassembling the case with it installed in the jeep.
Its only 15-20 minutes to pull the case. Half hour tops for somone new to it.
Support your motor and tranny with a jackstand
Drop the t-case skid
Undo the following
Rear shaft
Vacum line for case vent on top of case
Speedo cable
4wd sensor plug
Pry the 4wd shifter link out of its seat
Undo the 6 bolts that hold the t-case in. Typically 14 mm or 9/16's.
Pull the case out.
Put it up on the bench.
Head to a site like Stu Olsens, look up SYE install. Follow his pictures and direction on how to split the case.
Clean up, re seal the case halves and re install the case.
If you have a day to kill, its not to bad of a job.
Good luck
« Reply #8 on: October 24, 2006, 10:57:07 PM »
I'm a teacher, so I do end up having a day to kill - it's just a matter of scheduling it with the family.  :lol:
Thanks, that will help a lot.  I will look into getting a sye, and going that way, as I was planning to raise the jeep up some more than the current 3" bodylift as well.
