Author Topic: budget boost  (Read 880 times)
merlin
budget boost
« on: November 07, 2006, 10:35:13 PM »
so after adding my winch and joels ARB bull bar i got a little sag in the front of my jeep (you'll see if your at the run on the 12th). so now come the big mod, the lift. Now i have been told go big, go small, go cheap.....So i need some help. in the end i would like to run 33's or 35's. Im kinda limited for funds right now so i dont plan on having this ready until the spring. So please help shead some light this....
budget boost
« Reply #1 on: November 07, 2006, 10:40:30 PM »
YJ, right?
merlin
budget boost
« Reply #2 on: November 07, 2006, 10:46:01 PM »
sorry should have stated that, its a 04 Tj Sport columbia edition
budget boost
« Reply #3 on: November 08, 2006, 07:06:31 AM »
Well first off decided whether it will be 33s or 35s.  If you go to 35s, don't forget about re-gearing and if you are regearing you might as well put a locker in.  Also with 35s, you will need a SYE and new rear driveshaft.  Then if you have a d35 rear axle you will be replacing that with something stronger.  The lift is the easy part.
I am a YJ owner but I have seen my fair share of TJs.  To run 33s comfortably you need about 4" of lift and 35s are about 5-6".  Now this is just a rule of thumb.  JP mag fit 35s on a TJ with a stock suspension, lots of cutting.  33s can be fit on a budget nicely with a 2" BL and 2" budget boost, and new shocks.  No gearing necessary but would be helpful.
Do some research, look around, and decide what you really want this for, offroad only or mostly a daily driver.  Then it will be easier to ask question.  There are lots of great boards in the US like Pirate and Jeeps Unlimited.
