Author Topic: 4WD Problems - FIXED  (Read 1405 times)
Offline TaTtOo
    • http://www.lawrencemuller.com
« on: November 23, 2006, 09:07:47 PM »
Anyone have any idea why my 4wd would stop working out of the blue?  When I switch to 4 high nothing happens and when I switch to 4 lo it seems to be 2 lo.  And the 4wd light is not coming on now (i guess because it is not engaging).  Any ideas?
Cheers
Lawrence
Jeepless (for now)
Offline cotaman
« Reply #1 on: November 23, 2006, 10:14:23 PM »
that is the front axle disconnect vacumn piece of crud acting up :roll: ... crawl underneath and check to see if all you vacumn lines are still attached... it just takes one to fall off in that system and suddenly your in 2 wheel drive :shock: .   if that doesn't solve it.. check to see that you didn't break the shift fork in the front axle.... been known to happen.
Eugene
should have grabbed that posilok when i still had it :P
« Reply #2 on: November 24, 2006, 07:17:28 AM »
Yep vacuum disconnect.  I had the same problem, but I was able to my hands on a free one.  Anyways here is a link to check out
http://www.4bangerjp.com/forums/viewtopic.php?t=506
It should enlighten you on all things vacuum disconnect
« Reply #3 on: November 24, 2006, 08:17:40 AM »
Quote from: "BlackYJ"
You have to log in for that link.
« Reply #4 on: November 24, 2006, 08:25:14 AM »
Quote from: "dunl"
So whats you point.  If you want a bunch of GOOD info, then register  8)
« Reply #5 on: November 24, 2006, 08:52:47 AM »
There's GOOD things about 4 bangers?  :lol:
« Reply #6 on: November 24, 2006, 09:10:37 AM »
Damm, bite my tongue - that's a good site.  :)
Offline TaTtOo
« Reply #7 on: November 24, 2006, 09:24:53 AM »
WOW I wish everything was as easy to fix......... the hoses were lose... done thx for the speedy replies
Cheers
Lawrence
Jeepless (for now)
