Author Topic: I have a 96 cherokee, can I swap with a ZJ axles???  (Read 976 times)
Offline caar
« on: November 25, 2006, 10:58:07 AM »
Hi,
Here I go with a dumb question, I do not know anythig about axles!
I have a 96 Cherokee, with Dana 35C rear and 30 front
Limited slip in the rear
is there any advantages in installing ZJ axles???? will they fit????
what about the t-case? will it fit my XJ
I have 33's what kind of gears should I use in the diffs?
Thanks in advance
Regards
Carlos
Carlos
96 XJ, 33s, Winch
85 VW-Bombardier Iltis (Typ 183)
Offline cablesmurf
  • Relapsed Jeep Addict
« Reply #1 on: November 25, 2006, 04:04:00 PM »
There is no real benifit to swaping the axles except that the ZJ 35 with had disc brakes. You will have to cut off the coil mounts and weld in leaf spring perches...which is way too much work for a dana 35. You are better off lloking for an XJ dana 44, which is way stronger and is a direst bolt in.
The front, there is no benift at all. they are the same diff. Some ZJ's came with CV joints, which was very bad...watch for that.
Talk to bogjr on here...he has a dana 30/44 combo with 4.56 gears and a detroit locker in the rear, which would bolt right into your XJ.
They are hard to find, and even harder to find done up like that...so I would certainly jump on it.
The t-case would fit, but I see no advantage, unless yours is pooched.
Smurf.
