Author Topic: No start?  (Read 1529 times)
unsung_hero
No start?
« on: November 26, 2006, 08:18:05 AM »
when i go to start my 89 yj everything in inside will turn on but when i turn the key to start all i get is a tick and it dies i just replace the starter the batteris not dead  any ideas would help
No start?
« Reply #1 on: November 26, 2006, 09:14:17 AM »
Bad connections or cables? Have you tried boosting it? Sometimes a battery can have a bad internal connection that only shows up under heavy load.
Offline Gearhead
No start?
« Reply #2 on: November 26, 2006, 04:47:15 PM »
Check the ground connection on the starter relay.
Check battery terminals and starter connections.
A load test of the battery should tell you it's condition.
How old is this battery ?
unsung_hero
No start?
« Reply #3 on: November 26, 2006, 08:08:34 PM »
all  conections are good  battery was bought last year
dieseldude
No start?
« Reply #4 on: November 26, 2006, 09:55:46 PM »
I have the same problem with my 90 cherokee,  But I figured out that it was the neutral safety switch.  I just shift between park and neutral for now until I can change it.  It might be that.
unsung_hero
No start?
« Reply #5 on: November 27, 2006, 09:22:20 AM »
i drive a 5 speed manual
