Author Topic: Sway Bar end links  (Read 1027 times)
Offline ndub
Sway Bar end links
« on: December 11, 2006, 03:08:56 AM »
Trying to get the new ones in...but have been unable to get the broke bolt action out of the sway bar end (the top end bolt that fails)...Does it actually have to screw out or do I continue to use the BFH? (02 TJ)
Thanks for the help in advance [/url]
Sway Bar end links
« Reply #1 on: December 11, 2006, 07:59:28 AM »
Its a tapared fit.
Get a freind, or the wife to help.
Have them hold a small pickle fork around the ball and apply some pressure.
Take 2 hammers, and smack the the swaybar, (not the bolt) from both sides.
Repeat that as many times as it takes. Eventually, the tapared bolt will just vibrate loose and pop right out.
hth
Offline fony3
Sway Bar end links
« Reply #2 on: December 11, 2006, 08:37:30 AM »
When I swapped out my end links, I just went to crappy tire and rented a tie rod remover.
Offline TrappersJeep
Sway Bar end links
« Reply #3 on: December 11, 2006, 09:43:53 AM »
Quote from: "fony3"
Part Source "rents" the removers as well...they just take a security deposit and it's returned when the tools are returned
RIDER PRIDE IS OUTTA CONTROL!!  CRACK THE PIL AND BRING ON THE CUP!!!
Offline ndub
sway bar end links
« Reply #4 on: December 11, 2006, 10:12:15 PM »
Got the pickle fork stuff from PartSource up the road....Couple good hammer throws took care of it all. Thx for the help
Sway Bar end links
« Reply #5 on: December 12, 2006, 07:41:37 AM »
You're welcome
