Author Topic: TJ flares on a YJ  (Read 1198 times)
TJ flares on a YJ
« on: December 11, 2006, 09:07:47 PM »
Got a 95 YJ with a 3" BL.  If I got a set of TJ flares to swap with the current flares, two questions:
1 - is there anything different to do with these, or is it a simple cut and replace?  i.e. couple of different mods you could try, or just the one thing?
2 - what could I stuff under there - 33's?
Thanks.
TJ flares on a YJ
« Reply #1 on: December 11, 2006, 09:37:05 PM »
Here is a website for you to look at, http://www.bc4x4.com/tech/2001/tjflares/.  Depending on how crazy you get with the cutting tool you may have ot weld the inner and outer fenders back together.
As for tires size, I hope the 3" BL is just temporary, but 33s probably should fit with minor rubbing and if they do rub just a 1" shackle lift and you should be set
TJ flares on a YJ
« Reply #2 on: December 11, 2006, 09:40:47 PM »
The 3" BL came with the Jeep....why should it just be temporary?
TJ flares on a YJ
« Reply #3 on: December 11, 2006, 10:00:03 PM »
3" BL puts a lot of strain on the body bolts, plus in my personal opinion I don't like the look of them, but the strain is the major reason
TJ flares on a YJ
« Reply #4 on: December 11, 2006, 10:04:46 PM »
How bad are they for it? Should I be getting rid of it, or is it just not adviseable?
Quote
Put this under reasons why I don't own a sawzall....they're waaaayyyyy too much fun.
 :twisted:
Offline cablesmurf
  • Relapsed Jeep Addict
TJ flares on a YJ
« Reply #5 on: December 11, 2006, 10:50:01 PM »
3" BL's are fine...steve Jueco has been running a 3" BL on his TJ since '98 and his Jeep has been thru hell and back.
Might not be so great on a rusted out old CJ, but it'll be fine on your YJ.
People run them all the time. :roll:
TJ flares on a YJ
« Reply #6 on: December 11, 2006, 10:52:05 PM »
Well, that would be a good thing, as it appears to be welded into place.  :shock:
TJ flares on a YJ
« Reply #7 on: December 12, 2006, 07:53:34 AM »
You will want to stitch the sheet metal back together if you cut the full amount to actually accomadate tj flares.
With TJ flares, and a 3inch BL, 33's would be easy, and 35's would not be to hard.
TJ flares on a YJ
« Reply #8 on: December 12, 2006, 09:33:03 AM »
Good, planning a small spring lift as well, so there will be room to grow.  :)
