Author Topic: ZJ Transfercase problems  (Read 3664 times)
bozarelli
« on: December 12, 2006, 09:19:44 PM »
I really could use some experienced help with my 95 Grand, the t-case is really starting to rattle and shake , i'm told it is the t-case and i need to replace it for around $2500 bucks ...what can a guy do is there somewhere i can get a used one or rebuilt for alot cheaper?
« Reply #1 on: December 12, 2006, 10:35:09 PM »
Do a Google search for "ZJ 231 swap".  You can find them for about $200 if you look hard enough.
« Reply #2 on: December 13, 2006, 07:41:24 AM »
Try the gear center for a rebuilt, or jeepstuff for used
Gear center 252-3880
Jeepstuff 681-5337
I could change it for you, if you want.
A rebuilt from gear center with 1 year warrenty shouldnt be more then 1500$. RnR is only 1-2hours.
If jeepstuff has one, it would probably be about 800.
« Reply #3 on: December 13, 2006, 03:30:13 PM »
Think I know where you can get a used TC for $450
It's the NP242, right ? (shift pattern 2wd - 4part-time - 4full-time - N - 4LO)
Offline ramtuff
« Reply #4 on: December 14, 2006, 08:30:23 AM »
what model of t.case, 249?
pm me your vin# and I'll tell you what t.case you have.
Killer Off Road Equipment
Offline Matt4x4
« Reply #5 on: December 14, 2006, 05:06:21 PM »
Ya, dont spend the grand or 2 to replace it just do the swap to 231 and your good. If its even the TC. I would bet its something down the line, in the drive train. U joints even. My rig I thought it was the TC but in fact it was a messed up rear diff. Also be sure your fluids are topped up.
Jeepstuff will charge you alot for a used unit. $800 abouts. Just do the swap from full time 4wd (249) to part time 4wd (231)
bozarelli
« Reply #6 on: December 14, 2006, 09:41:06 PM »
Wow quick response time...thanks for all the tips guys , what i would really like to know about is the T-case swap ...231? was it..anyone here in Calgary done this swap out out? and It is the T-case i have replaced everything else already.../sigh...and its the 249 i think,  fulltime 4WD woohoo../sigh
Offline XJHERO
  • Soberphobic
« Reply #7 on: December 14, 2006, 09:49:12 PM »
I have a 231 in my garrage we have been trippen over for awhile probly 100bucks takes it 8)
DD
Get at me Wolf
« Reply #8 on: December 15, 2006, 11:36:14 AM »
Send a PM to Dan (cablesmurf).  I think the XJ 231 is different, and you need a TY or YJ 231 case.
Also, if you haven't yet, go to www.nagca.com
Lots of good info there.
« Reply #9 on: December 15, 2006, 03:39:14 PM »
if u have all wheel drive you have the 249..... if it is the 249, and you tcase is on its way out, the swap to a 242 is quite easy from the looks of it. i havne't done the swap yet but i will. its basically a direct swap. just have to make sure your imput shafts are the same. it'll be either 21 or 23 spline. if the 242 is different from your current 249 you can swap the sun gear and the input from the 249 into the 242 and it should all bolt right up.
i second the idea of goin to www.nagca.com. i'm on there all the time, lots of people have done these swaps.
« Reply #10 on: December 15, 2006, 04:57:00 PM »
Just a word of caution....they can be real pricks to newbies on there if you don't do a search first.  So search for "231 swap", and then ask specific technical questions instead of general.
Don't get me wrong, lots of good people on there.  Lots of idiots as well.
Trouble Maker
« Reply #11 on: December 15, 2006, 06:06:34 PM »
94 and earlier have a different gear cut on the planetary gears and the input shaft from 95 and up will not engage properly in the planetary (and vice versa). My 93 had a 95 249 in it and when I went to the 242 I had this problem. I ended up using my 95 249 front case, input and planetary with the rear case and all the guts from a 92 XJ 242 when I did my swap.
 The 242 & 249 front case halves are almost identical and will bolt up with either back half. The 231 case is shaped different and will only swap with other 231s.
« Reply #12 on: December 16, 2006, 01:12:18 AM »
ya, shoulda mentioned that too... thanks for that added info.... just a link if your curious about how to swap out the inputs if you might wanna do this;
http://cherokeekid5.tripod.com/t_case.htm
