Author Topic: I'm stalling at lights  (Read 1886 times)
CJ-7
« on: July 15, 2005, 09:13:37 AM »
Ok just got everything fixxed on the cj.
Then,,,,,,,,,,,
Engine 2.5l   4 cyl  carb   manual   amc
Yesterday when I got home the jeeps idle was off. Sounded like it was missing.
 So today I replaced the dist cap ... rotor.....fuel filter......plugs
And it is still doing the same thing. Rough idle and stalling. It runs ok when the gas is applied. Idle not s good  :(
 A few guys here at work suggested :
-vacuum leak
- but one was saying there might be some problems in the distributor itself.
Not sure where to start..........................    please help
Offline bae146
Idle problem
« Reply #1 on: July 15, 2005, 02:12:19 PM »
My 4.2 would do the same thing.  The idle jet was plugged in mine.  If your carb is anything like the one I had just remove the idle jets from the carb and clean them out.  This should solve the problem.
RUBI
trouble
« Reply #2 on: July 15, 2005, 07:11:52 PM »
Also check for a sticky float (tap the carb with nylon hammer or screwdriver end) or possibly fuel pressure problem??
CJ-7
« Reply #3 on: July 16, 2005, 06:38:49 PM »
K dudes!!!!!!
   Took it in for a dia.    He said is is def the carb. Internals are screwed somehow!!
  Anyways i was wondering if there was an aftermarket one I could throw on? I do not know much about carbs but I know mine is old and prob. lacking power because of it. He adjusted it so it runs fine but says that I should get a rebuild or new one.
     Thank you to all who helped!!!!!!!!!!!!!!
Offline blaker
    • http://www.snojet.com
« Reply #4 on: July 18, 2005, 10:42:58 AM »
I'd look into getting a new edelbrock carb.  I just got one installed on my 360 AMC, had some troubles at the start, similar to yours, but after a quick tune up, new plugs, pcv valve and dsitributor cap, it's running nice and smooth.
