Author Topic: gauges not working .....!!! what the deuce?????  (Read 865 times)
skeeter08
« on: January 02, 2007, 12:36:23 AM »
all of my gauges just stopped working???? but i'm still able to drive the jeep and my lights work???
has anyone had this problem before???
Offline cotaman
« Reply #1 on: January 02, 2007, 02:04:27 AM »
check the connection between the computer and the dash...... i had the same thing happen on a 03 dodge qc 4x4..... turned out there was some corrosion at that connection.... :)
Offline murdajeep
« Reply #2 on: January 02, 2007, 10:11:17 PM »
yo browner!!!
Worden and  me fixed the same thing in rhinos old jeep.
I just removed all the consoles and the light switch and
reattached them and the lights on the dash then came on.
Don't really know what was causing them to not come on but
we got it fixed.
Murdajeep
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #3 on: January 02, 2007, 11:09:08 PM »
What you are experiencing is tremendously common on TJ's.  Its a result of a poor connection to your instrument cluster.   There was a Technical Service Bulletin on this.  Under warranty they would replace the cluster.  This isn't necessary.  You need to get your Cluster out.  Then gently twist the pins and use a little dielectric grease.  Then reassembly your dash.  This should take care of your problem.
98 TJ 4" lift + goodies
skeeter08
« Reply #4 on: January 03, 2007, 10:59:52 AM »
thanks boys
