Author Topic: High-pitched noise  (Read 1505 times)
Pyro
High-pitched noise
« on: January 31, 2007, 11:13:44 AM »
I have a squeeking noise comming from somewhere in the rear half of my TJ.  When I speed up, the sound does as well.  It also only makes this sound when it's cold out.  It sounds like the same noise my front wheel bearings made before I replaced them, but I'm assuming the rear bearings are a much different setup.
Any ideas?
Offline apex
High-pitched noise
« Reply #1 on: January 31, 2007, 01:29:55 PM »
forgive the pun.. but it sounds like a u-joint to me
High-pitched noise
« Reply #2 on: February 01, 2007, 09:01:51 PM »
Does it squeek with the clutch out sitting at a stop?
Pyro
High-pitched noise
« Reply #3 on: February 02, 2007, 02:31:42 PM »
Nope it only does it while moving.  The clutch being in or out makes no differnce either.
High-pitched noise
« Reply #4 on: February 02, 2007, 02:36:03 PM »
Pull your front driveshaft and see if it goes away.
Pyro
High-pitched noise
« Reply #5 on: February 02, 2007, 03:14:15 PM »
Quote from: "bnine"
I've had my front u-joint replaced around 5K ago under warantee.  Could it be my rear u-joints?
High-pitched noise
« Reply #6 on: February 02, 2007, 03:22:59 PM »
The CV joint on the front DS has a tendency to wear and make noises
