Author Topic: body lift and 33's  (Read 2482 times)
Offline murdajeep
body lift and 33's
« on: February 27, 2007, 08:35:36 PM »
I have a 2.5" suspension lift on my 91 jeep YJ and I was
wondering if I put a 1.25" body lift on it if I would be able
to fit 33's under there untill I get my 4.5" lift later in the summer.
I know it will prob rub a bit and I am not to worried unless it just totally
won't work.
any thoughts from u guys will be much appreciated
Murdajeep
body lift and 33's
« Reply #1 on: February 27, 2007, 09:10:43 PM »
Do you have TJ flares on it?
I would recommend the 1" body lift and a 1" shackle lift.  I ran that setup with a 2.5" OME lift for a couple years and it worked great, but I have TJ flares and I definitely needed the space as my springs flexed very well.
You can get Performance Accessories shackles for about $50/pair or you can go greaseable at about double the price
Offline murdajeep
body lift and 33's
« Reply #2 on: February 27, 2007, 09:13:01 PM »
ya i got some bestop 6" flares that came with the jeep when i bought it.
will those work?
Will the shackles change my drive line angles?
Murdajeep
body lift and 33's
« Reply #3 on: February 27, 2007, 09:33:32 PM »
The shackles will help in the rear and hinder in the front.  HOWEVER, anything around 1" or less of lift will not be noticable.  To achieve a 1" lift in a shackle, the shackle actually needs to be 2" longer than stock
As for the flares, they are probably just the YJ bestops, and I am not sure if they provide anymore room
If you find you are rubbing a lot then you will have to extend your bumpstops
Offline murdajeep
body lift and 33's
« Reply #4 on: February 27, 2007, 09:37:42 PM »
sweet thx for the info.
I will just make sure my u-joints will be in good condition.
I will just have to use trial and error for the fenders.
thx
Murdajeep
Offline Gearhead
body lift and 33's
« Reply #5 on: February 27, 2007, 09:46:20 PM »
Those Bestop flares only get you some tire coverage with additional width , no clearance . I've got a set , they were on my 88 for a couple of years w/ 4.5" RE springs and 33's , the tires rubbed when the jeep was flexed. The Bestop flares are on my 94 YJ now , it's spring over and runs on 33's , clears fine like that ,  I could easily fit larger tires but that would only invite axle breakage and other problems. Both Jeeps have extended bump stops. The 88 still has the RE 4.5" springs ( nice !) but now has Bushwacker cutouts. My plan is to install a 1" body lift and trim the fenders , this is in preparation for my newly puchased 35's, this will get me the lift , flex and clearance I'm after.
33's need some carefull planning to get proper clearance , especially if you start flexing it out.
Offline murdajeep
body lift and 33's
« Reply #6 on: February 27, 2007, 09:52:17 PM »
the bushwacker cut outs have better clearance for flex then the bestop ones i am assuming cuz u put them on the 88?
or should i look around for a set of tj flares
Murdajeep
body lift and 33's
« Reply #7 on: February 28, 2007, 07:25:59 AM »
Quote from: "murdajeep"
thx
Since you have a high pinion D30, the front is hardly affected in terms of driveline angle, it just changes the caster slightly
After seeing SEVERAL bushwacker flares pop off and and shatter, I would not recommend a set if you are doing any serious offroading.  I would definitely go the route of TJ flares whether they are aftermark or not.  Rubi and Sahara flare are 1.5" wider than stock TJ flares
Offline Gearhead
body lift and 33's
« Reply #8 on: February 28, 2007, 08:29:43 AM »
Quote from: "BlackYJ"
thx
Define "serious offroading"
body lift and 33's
« Reply #9 on: February 28, 2007, 08:35:06 AM »
Quote from: "Gearhead"
Lets put it this way, if you are on 33s you are probably going to be doing some tough and technical trails, so therefore I personally would not run bushwackers from what I have seen.  They are too brittle and tend to break rather than bend like a Warn
Offline murdajeep
body lift and 33's
« Reply #10 on: February 28, 2007, 06:15:27 PM »
sweet thx ya i have never heard that about bushwackers so know I know to stay away.  I think my buddy has an extra set of tj flares laying around i will have to talk to him
Murdajeep
Offline Gearhead
body lift and 33's
« Reply #11 on: February 28, 2007, 07:17:16 PM »
I've heard that they are easily broken as well , have also heard  they are tough as the rest. I do know this , whatever brand chosen , none are cheap so it would be a shame to bust em up. I've "tested" my Bestop flares a couple of times , even destroyed a fender , the flare was intact except for a small crack where the main part of the  flare joins the extension minor damage , still functional.
The recently puchased / installed Bushwackers ? , although they have been offroad twice , I havn't "tested" those yet , I'm sure they bash something sooner or later ,  then we'll see how tough they are.
Offline murdajeep
body lift and 33's
« Reply #12 on: February 28, 2007, 08:30:24 PM »
k sweet.
but another question to Black yj I looked on quadratec and they have shackles that are 1" lift and ones that are 1 1/4" lift for performance accesories.  Which ones do i go with cuz u said it takes 2" of shackle lift to raise the jeep 1"
Murdajeep
body lift and 33's
« Reply #13 on: February 28, 2007, 09:10:47 PM »
I got the ones that were 1", however looking at the Performance Accessories website they say they measure 5-3/4" and 1" of lift.  If you want a GREAT shackle that will perform with any spring, have a look at the MORE Boomerang shackle, they are shaped like a "7".  In the rear they provide a lot more flex and in the front they prevent shackle inversion, which can destory leaf springs.  Now they only came in 3/8" and 5/8" lift.  I recently installed the 5/8" lift ones both front and rear on my YJ.  These shackles are BEEFY, 3/8" thick plate, plus they are greaseable.  I talk about them on my build thread in the Projects section.  They will not provide the total of 1" of lift but these shackles will definitely work.
Hope that helps
Offline murdajeep
body lift and 33's
« Reply #14 on: February 28, 2007, 09:27:56 PM »
yes that helps a lot
thx  :D
Murdajeep
