Author Topic: transfer case  (Read 941 times)
evasion1
transfer case
« on: March 05, 2007, 09:26:33 PM »
can some one tell me what is the defens   betwean a cyl and 6 cyl t case is ?  hopfuly some one knows  thanks
transfer case
« Reply #1 on: March 05, 2007, 09:31:09 PM »
I am guessing you meant to say 4 cylinder.
The only difference is that the 4 cyl versions have 21 spline input and the 4.0L have a 23 spline input due to the different trannys.  Now XJs case are clocked slightly lower than the YJs and TJs but still exactly the same
evasion1
transfer case
« Reply #2 on: March 05, 2007, 09:42:10 PM »
so if you have a 4 cy  t case  what do you have to do to make if work for the 6 cy
Offline laredo
transfer case
« Reply #3 on: March 05, 2007, 09:48:28 PM »
I had to swap out the input shaft to hook up to the ax 15
evasion1
transfer case
« Reply #4 on: March 05, 2007, 09:55:08 PM »
ya how much is the out put shaft
Offline laredo
transfer case
« Reply #5 on: March 05, 2007, 10:44:34 PM »
I took the input shaft out of my busted case and into the new one.
this link might help for a new one.
http://www.novak-adapt.com/knowledge/np231.htm
