Author Topic: loose wire??  (Read 840 times)
Giffer
loose wire??
« on: March 05, 2007, 10:49:24 PM »
ok... like the title says i think its a loose wire but heres the problem, it wont start some times. but if i give it about 20 minutes to a half hour it will start up, no boost, nothing but sitting there. and no its not over heating, and my battery has a charge. oh and this only happens after i turn it off. it doesnt matter how long its been running. its happened to me twice now and last night when i was on my way home from the LOG concert it did it to me again at timmys. that sucked. any ideas??
Offline laredo
loose wire??
« Reply #1 on: March 05, 2007, 10:51:59 PM »
check the battery cables.
I had something like that happen.I cut off tthe existing battery connections , and put on new ones after cleaning the lovely green crap off the wires.
loose wire??
« Reply #2 on: March 06, 2007, 06:39:11 AM »
Just had that happen to my ZJ.  Loose grounding wire to the PCM, wasn't being pinched by the battery terminal to maker a good connection.
frozennorth
loose wire??
« Reply #3 on: March 24, 2007, 05:58:55 PM »
Check the starter.  Had one that the bendix would not engage
if it was hot.  Many bad words till I found the problem.
