Author Topic: 03 tj rear shock bolt broken  (Read 1497 times)
Offline XJHERO
  • Soberphobic
« on: March 08, 2007, 06:25:12 PM »
its on the driver side in the back the inside top bolt for rear shock.
The bolt is broken off flush in the square nut thats welded on the inside of the frame. Does that make any sence to any one?
I think the best way is to break off the nut cus u cant get straight on it with the drill to drill it out  the gas tank is in the way.
any suggestions???
DD
Get at me Wolf
Offline XJHERO
  • Soberphobic
« Reply #1 on: March 08, 2007, 09:59:11 PM »
bump
Bnine?????????????? 8)
DD
Get at me Wolf
« Reply #2 on: March 09, 2007, 07:05:54 AM »
BFH and duct tape, you can't go wrong  :D
Get some bar pin eliminators after you get it out
Offline ramtuff
« Reply #3 on: March 09, 2007, 09:27:25 AM »
Quote from: "BlackYJ"
break the welded nut off and get some bar pin eliminators.
Killer Off Road Equipment
« Reply #4 on: March 09, 2007, 09:58:21 AM »
Drill through, then nut and bolt is the quickest and easiest.
The 1/2" air drill I have reaches up there.
You can try and easy out and then reuse the welded nut, but I havnt had luck with that method.
Offline XJHERO
  • Soberphobic
« Reply #5 on: March 09, 2007, 01:53:34 PM »
thanx guys
got the bar pin elimintators already
DD
Get at me Wolf
