Author Topic: 4cyl t case  (Read 1163 times)
evasion1
4cyl t case
« on: April 09, 2007, 11:44:35 PM »
does any one know if a 4cyl t case will work in a yj ? or what you have to do to get it to work ? any help would be appreciated  thanks
Re: 4cyl t case
« Reply #1 on: April 10, 2007, 07:12:49 AM »
Quote from: "evasion1"
I am not sure where the 4cyl t-case is coming from, but all TJ and YJ 4 cyl t-case should be interchangeable, except for maybe the ones behind the 2.4L.
evasion1
4cyl t case
« Reply #2 on: April 10, 2007, 07:26:06 AM »
i had a 4cyl t case given to me and mine got stolen off my jeep  mine has a 4.0 l in it  so i dont know ?
4cyl t case
« Reply #3 on: April 10, 2007, 08:08:01 AM »
Well putting a 4 cyl t-case into a 4L driveline is a different story.  The 4L t-cases have 23 spline input and the 4 cyl have a 21 spline input gear.  The rest of the case is the same, but the input gear need to be swapped
Offline kenny kustom
4cyl t case
« Reply #4 on: April 10, 2007, 08:25:16 AM »
How does one steal a t-case ?  :shock:
evasion1
4cyl t case
« Reply #5 on: April 10, 2007, 09:01:45 AM »
dont know it was parket all winter whent to pick it up and no t case   skide plate is there  drive shafts are there but know  t case  :?
evasion1
4cyl t case
« Reply #6 on: April 10, 2007, 01:17:32 PM »
so any one know how to change the shaft in this and where do i get one from?
Offline AMCJeep
Re: 4cyl t case
« Reply #7 on: April 10, 2007, 09:46:47 PM »
I have a 4 Cyl T-Case in my 4.2L 6 Cyl YJ.
If your 87-90 6 cyl YJ has the BA10/5 transmission then it has a 21 spline output the same as any TJ/YJ/XJ 4 Cyl. NP231, a direct bolt in!
 If you are so inclined you can also swap your input shaft into a 4 cyl T-case easily.
HTH
03 Ram 2500 QC, LB, 5.9 CTD
