Author Topic: 297s vs 760s  (Read 1124 times)
297s vs 760s
« on: April 16, 2007, 12:36:16 PM »
Well I am looking to get some new u-joints for my front axle and I am tore between the 297s and the 760s.  Now here are my thoughts
First - 95 YJ with 4.0L and 33s, disco passenger axle
-The 760s are a stronger joint and therefore should last longer and be more resilient to breakage
-However if I go with the 760s do I then make the axle the weak link in a breakage situation.  I would rather break a joint than an axle
-I am still running the stock 297 joints now, and my YJ has 165,000 km on it, so do I really need the upgrade.
-Finally they are the same price, so that is a wash
Let me know your thoughts
Offline calltrex
297s vs 760s
« Reply #1 on: April 16, 2007, 10:50:25 PM »
Get the Alloy x joints
better then 760s and have bigger needle bearings and are greaseable but not the expense of CTMs
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
297s vs 760s
« Reply #2 on: April 17, 2007, 07:08:30 AM »
Quote from: "calltrex"
I don't like greaseable and I have never had a problem with Spicers.  The Spicer triple seal joints do not let any crap in.
Offline calltrex
297s vs 760s
« Reply #3 on: April 17, 2007, 07:22:36 AM »
but the smaller needle bearings could crush and fail the joint
if u dont got chromos then dont worry about it
........___________
.../""""/........J
297s vs 760s
« Reply #4 on: April 17, 2007, 08:13:30 AM »
Well I am still on the factory joints so I think the standard design will be fine and I don't have chromos.
After some searching, it does not look like the 760s are that much stronger so I will probably land up going them those.
Offline calltrex
297s vs 760s
« Reply #5 on: April 19, 2007, 09:54:43 PM »
297x is cast
760x is cold rolled steel stamped out
297x has grease channels that run almost the whole way
760x has grease channels that run only 2/3 the way
297x has slightly larger body
760x has better seals to keep dust/mud/grime out
Both have the same max (garunteed) load rating
Spicer said that in reality the 760x was slightly stronger.
........___________
.../""""/........J
Offline Rookie
297s vs 760s
« Reply #6 on: April 20, 2007, 12:57:54 AM »
Scott 9 X outta 10 if the joint lets go it will take the ears on the shaft out anyway
TJ with some stuff
297s vs 760s
« Reply #7 on: April 20, 2007, 07:26:05 AM »
Quote from: "Rookie"
Yeah that is what someone mentioned on the ECO and I know it is usually true
Thanks for the info Dave
Offline calltrex
297s vs 760s
« Reply #8 on: April 23, 2007, 09:10:27 PM »
I just changed my front axle u-joints tonight because i had no idea on their condition or how long they have been in.
half of the caps were rusty and dry.  Cant have that when i goto moab in 2 weeks.
I put 760s in until my good ujoints get here.
........___________
.../""""/........J
