Author Topic: which way should I go ????  (Read 1034 times)
Bone Shaker
« on: April 28, 2007, 09:22:04 PM »
put in the 4 inch lift, put on the 33" tires and now I think I want to upgrade my drivetrain. The four cylinder is fine but I want more power. I was thinking of buying a junker XJ and pulling the drivetrain out and put it in my YJ or does anyone have any better idea's. I don't like the idea of messing around with driveshaft's so I thought I should keep it all Jeep.
With all the experience on this board I hope to get some good advice.
Thanks for any idea's
John
 :D
mudslinginjoel
« Reply #1 on: April 29, 2007, 09:45:25 AM »
if your lifting it 4 inchs,I'm not positive,but I think youll have to modify your rear shaft,I think the 4.ol(6cyl.)would be a really good swap,and keeping it all jeep will make a heck of alot easyeir!
Bone Shaker
« Reply #2 on: April 29, 2007, 10:54:37 AM »
the lift is already in and I did not have to do anything with the rear shaft so then it should be a straight swap over. I am going to look at a donor xj on Monday and I am hoping my luck will be in and it will have a rear 44. Does anyone know what years and models had a 44 ??
thanks
John
« Reply #3 on: April 30, 2007, 08:28:05 AM »
Last year I swapped in the drivetrain from a XJ into my YJ to replace the angry squirrels, it was a great swap.  However it still is a lot of work and just to point out, the 4.0L drivetrain is longer than the 4 banger, so your rear shaft will be SHORTER.  Therefore you will probably need a SYE kit and a CV shaft or a motor mount lift and t-case drop.
As for the XJs with 44s, I believe the most popular is around 87-88
Offline kenny kustom
« Reply #4 on: April 30, 2007, 10:18:36 AM »
Just a comment, But . I am running 40" irocks and D60's with my 4 banger. Its all in the gears...
