Author Topic: CJ Gear Ratio  (Read 1394 times)
Offline blaker
    • http://www.snojet.com
CJ Gear Ratio
« on: May 06, 2007, 03:40:01 PM »
Just curious what the stock gearing in my jeep would be. Its a 79 CJ7, and originally would have had a 304 V8. Its a Quadra-Trac, AMC20 Rear, D44 in the front. I can't find any ID tags, or markings.
The reason I'm checking is with 35's now, its a bit under powered. I also think I blew my rear locker, so if it's all going to be coming apart, I might as well looking at re-gearing.
Thanks!
JeepInMud
CJ Gear Ratio
« Reply #1 on: May 06, 2007, 03:44:34 PM »
I believe the choices for axle gears in those days were commonly 2:73 gears, could also be lower, but I doubt it with a 304 stock
Offline blaker
CJ Gear Ratio
« Reply #2 on: May 08, 2007, 08:32:19 PM »
So I cleaned down the area of the diff that is supposed to have the code, and looks like I've got "A". which is 3.54 for a narrow track axle. I suppose it could have been changed, but 3.54 sounds about right.
As for the carrier, I've read that they're different between the 2.73 and 3.31-5.13, so I'm in the right range, and think I'm going to try 4.10's (used to be 32's now running 35's).
Thanks!
