Author Topic: new gears?WTF  (Read 1351 times)
Offline 4PLAYZJ
new gears?WTF
« on: May 06, 2007, 05:53:15 PM »
I have never encountered this before.  I installed 4.88 gears in my ford 8.8. for my 93 ZJ.  I am using the stock limited slip carrier, which I believe is o.k. for high ratios.  When I go to put the pinion pin back in, the crown gear is hanging over too far.  I cannot reinstall the pinion pin.  Is this common with high gear installs?  The only way I am going to fit the pin back in is to remove a bit of material from one of the crown teeth.  The problem with that is that, is that in order to get a good pattern with this gear set I had to push the pattern to the crown toe and one tooth will be missing matterial close to the gear contact.  I know it doesnt matter for the drive side but I am worried I will get noise on coast.  Anyone who has encountered this let me know, because I am close thinking that the parts are faulty.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
new gears?WTF
« Reply #1 on: May 06, 2007, 09:50:10 PM »
On an FAQ on www.jeepsunlimited.com they say this:
Quote
Do I need a notched cross pin? Yes for 4.56-6.14 to clear ring gear, or notch a gear tooth.
in this thread:
http://www.jeepsunlimited.com/forums/showthread.php?t=674123
I haven't done the swap yet, but have been researching it.
98 TJ 4" lift + goodies
Offline BrokenAxle
    • Broken Axle home page
new gears?WTF
« Reply #2 on: May 08, 2007, 10:17:44 AM »
hey, i have done gears where i have had to shave the ring gear.  i have not noticed any noise or experienced any adverse side effects.  just remember to take off as little as possible!
Dave
Offline trackerthrasher
  • 74' CJ 5
new gears?WTF
« Reply #3 on: May 08, 2007, 05:06:01 PM »
I shaved the cross pin....again...as little as possible. :lol:
The one thing that unites all human beings, regardless of age, gender, religion, economic status or ethnic background, is that, deep down inside, we ALL believe that we are above average drivers.
Offline cuzican
new gears?WTF
« Reply #4 on: May 08, 2007, 05:35:10 PM »
I just put 4.56s in an 8.8 and I had to grind a small portion off one of the teeth to get the crosspin out. I had it installed when I discovered this so I covered everything up with plastic and duct tape except for the small operating area.
I used a die grinder and just cut away a small portion of a corner, enough for the pin to slide out one side.
The advice I'd gotten from a gear installer when I ran into the problem was to grind the gear not the pin.
Works fine.
Offline BrokenAxle
new gears?WTF
« Reply #5 on: May 08, 2007, 06:00:40 PM »
i would agree with grind the gear not the pin...
Dave
Offline 4PLAYZJ
new gears?WTF
« Reply #6 on: May 08, 2007, 07:45:40 PM »
I ended up doing a little of both.  I figured that if the goal was to do as little as possable I could remove less material splitting the difference between the gear and the pin.  Also if I had only done the gear I would have had to remove alot of material 4.88 hung over about 1/4'.
new gears?WTF
« Reply #7 on: May 09, 2007, 08:33:55 PM »
Get a new pin when you get a chance Dave. Million at pick n pull.
Lots of guys on JU have busted shaved pins. None of them have shredded shaved teeth.
I shave the teeth with a cutoff wheel. No noise or issues to date.
