Author Topic: pitman arm nut  (Read 2850 times)
bubba
pitman arm nut
« on: May 07, 2007, 03:10:47 PM »
Does anyone know the size of the nut on a 88 YJ pitman arm-thx
unionjack
hey
« Reply #1 on: May 25, 2007, 09:23:27 AM »
mine was vice grip size :lol:
Offline apex
pitman arm nut
« Reply #2 on: May 25, 2007, 10:03:18 AM »
at least its not sawzall size.  :lol:
/end hijack
Offline bae146
Wrench
« Reply #3 on: May 25, 2007, 01:20:54 PM »
Mine was crescent wrench size.  Just be careful to not use the metric crescent wrench!!!
CJ-7
pitman arm nut
« Reply #4 on: May 25, 2007, 01:32:06 PM »
Crescent wrench..........  aka several sixteenths :lol:  :lol:
Offline bae146
mm
« Reply #5 on: May 25, 2007, 02:38:55 PM »
Also known as many millimeters by the import crowd. :lol:
bubba
pitman arm nut
« Reply #6 on: May 25, 2007, 03:13:21 PM »
so helpful!!!!! :lol: -myslef and UnionJack have both tried with all of the above...less the sawzall-I think I need a bigger f wrench
unionjack
pitman arm nut
« Reply #7 on: May 25, 2007, 07:35:14 PM »
ahhhhh not the dreaded F$%K*#G wrench
Offline TaTtOo
    • http://www.lawrencemuller.com
pitman arm nut
« Reply #8 on: May 25, 2007, 07:50:41 PM »
I found a pipe wrench and BFH to be helpful
Jeepless (for now)
Offline bae146
18"
« Reply #9 on: May 25, 2007, 11:14:38 PM »
I used an 18 in crescent with a pipe over the end.  Wack the wrench with a hammer while pulling for all your might.  Wear GLOVES.  The thicker the better.
pitman arm nut
« Reply #10 on: May 25, 2007, 11:28:50 PM »
im gonna say its about a 29mm or 30mm, give or take. my impact gun works just fine taking them off... the perks of being a tech i guess. i forget which size it is because i just grab a socket from the set without looking.
unionjack
pitman arm nut
« Reply #11 on: May 28, 2007, 10:14:31 AM »
jamie im thinking your gonna have to cut that sucker off!!!!! time to break out the die grinder, or i can do it  if you really want me that close to your jeep with an angle grinder!!!!!!! :lol:
Offline Gearhead
pitman arm nut
« Reply #12 on: May 28, 2007, 02:33:39 PM »
1 5/16" is the closest size I've got . As already mentioned , a "stout" air impact gun has always worked for me , when combined with sufficient supply of air.  DO NOT beat on it , DO NOT use a torch ! .  I'm sure you have used plenty of penetrating oil . A long 1/2"(quality) breaker bar will loosen that nut too.
The pitman arm may or may not come off easily , use the correct puller , some patience and more penetrant . Apply pressure with the puller , walk away if it doesn't budge , leaving the puller on with tension on it . Several attempts may be necessary. DO NOT beat on it.
Don't make me come over there !
Torque the nut to 185 ft/lbs
bubba
pitman arm nut
« Reply #13 on: May 28, 2007, 06:27:20 PM »
Thx Jeff!-yeh we got it off today-filed down the sides of the nut and then slid a wrench  on it-started bending the puller-it was on so tight..thx for all replies-
