Author Topic: What to coat inside of YJ Tub with?  (Read 792 times)
Offline chrispl
« on: May 12, 2007, 06:11:24 PM »
Any suggestions? rhino lining? gator gaurd? rockgaurd? what works best? and where to buy? all tips and info appreciated :)
95 cherokee
Offline midnightcowboy
« Reply #1 on: May 13, 2007, 10:57:34 AM »
i used the hippo liner or whatever from crappy tire. 2 part. works well. make sure you have no oil or grease on the floor and scuff it up with some scotchbrite or some sandpaper. dont mix the whole thing at once as it hardens relatively quick. buy a couple extra texture rollers as you will need them. i did 2 coats on my whole tub and so far so good.
90YJGIMP
« Reply #2 on: May 18, 2007, 06:55:41 AM »
I used the Hippo liner as well, it worked well. Stuff i'm looking at now is called Raptor Guard. One of the autobody stores here had it, so i'm sure its available in Calgary. Its a rubberized bedliner like the Duplicolor stuff, but the rubber is stronger once dry and still flexible. Some auto body places have samples that you can check out to see if the product is what you are looking for. Just gotta ask.
