Author Topic: Sway Bar Seized  (Read 800 times)
jeeppilot
Sway Bar Seized
« on: May 13, 2007, 09:29:03 AM »
Any thoughts on how to seperate sway bar from the links if they're seized????   93 YJ
Offline Elsifer
Sway Bar Seized
« Reply #1 on: May 13, 2007, 09:43:07 AM »
A BFH. Well, tap the links from alternating directions to get the tapered pin to come out. Maybe hitting it a little harder than just tapping. :D
I'm sure there is some sort of puller that would work, but a hammer works with a little bit of elbow grease.
VA6CPL
Jeepless....
90YJGIMP
Sway Bar Seized
« Reply #2 on: May 18, 2007, 06:49:03 AM »
Also try applying Penetrating fliud to it for a bit. I had a siezed shock bolt that i hammered with a mallet (rubber/plastic ends) using the plastic side and lots on PB Blaster and 3in1 Penitrating fluid, took a while but it came out and didn't damage the bolt threads. I applied lots of anti-sieze to the bolt and threads prior to reassembly.
Offline stroker sahara
Sway Bar Seized
« Reply #3 on: May 18, 2007, 04:52:07 PM »
After dismantling my jeep completely and breaking numerous bolts, I am going to try to remember to put antisieze on every bolt.
