Author Topic: Rear tow hook  (Read 1334 times)
Robbman
Rear tow hook
« on: May 13, 2007, 09:26:31 PM »
hey guys, i called the dealership the other day and they priced out two rear tow hooks for my 98 tj at about 170 bucks :shock:
is there anything else i could use for a rear tow hook thats a bit cheaper :?:
or if anyone has an extra one they are willing to part with?
Robb
Offline RckyMtnTJ
    • http://www3.telus.net/lck
Rear tow hook
« Reply #1 on: May 14, 2007, 12:25:50 AM »
You can go to Princess Auto and get some 10,000lb tow hooks for under $10 each.  There is one hole in your frame on the side already, just line it up and drill the second hole.  There is a hole under the frame to fish your nuts up through.  Very easy.  I don't have a pic of the tow hook installed, but I do have a picture of two bolts through the holes I am talking about.  You can also see the hole in the bottom of the frame which you can fish the nuts up through.
HTH
98 TJ 4" lift + goodies
