Author Topic: Strange noise in my TJ  (Read 956 times)
deedle
« on: June 11, 2007, 02:31:28 PM »
I have an o4 TJ Sahara.  It is a 5spd.    Any time I am just crawling along in traffic in 1st gear I get a knocking noise when I let off the gas pedal.  It feels like it is in the area below my feet.   Anyone ever experienced this or know what it may be?      It only happens when I am going slow and I ease up on the gas pedal.
Offline Rig-Pig
« Reply #1 on: June 11, 2007, 07:32:54 PM »
i have found that the best way to get rid of strange sounds in my jeep is to turn up the radio..  :lol:
build 'em, break 'em,
love 'em, leave 'em
same thing
Offline cablesmurf
  • Relapsed Jeep Addict
Re: Strange noise in my TJ
« Reply #2 on: June 11, 2007, 08:46:34 PM »
Quote from: "deedle"
Bad U-joint...
Worn out bushing on the t-case shifter pivot (under Jeep)...you may need a relocation bracket with your lift.
Worn clutch...
Loose bolt...
deedle
« Reply #3 on: June 12, 2007, 10:12:46 AM »
Thanks for the input.    I checked with the guys that supplied my lift.  They tell me that relocation bracket is not necessary for my jeep and that it wouldn't be causeing that.    Personally, I am not a mechanic so I really don't know ecaxt;y what it is but I am told that mine is hard mounted.
As far as I can tell everything is nice and tight too.   I did have my front drive shaft redone recently so I checked that out but there is no play in the joints.     However, the driveshaft itself does rotate back and forth a little bit.  I know it does turn all the time even when I am in 2 wheel drive so I am wondering if that is what is causing the noise.   I just don't know why I never noticed it before.
