Author Topic: Braking causes stalling~  (Read 1519 times)
yjpaul
« on: August 11, 2005, 06:52:09 PM »
Im hoping someone knows what this problem is, but when im coming to a stop braking, the truck just wants to die, and sometimes does unless i have my foot on all three pedals at once.  Even at a stop if i pump my brakes, the rpms drop significantly.  Anybody?
« Reply #1 on: August 11, 2005, 08:23:39 PM »
Its possible that the check valve or diapram in your brake bosster is bad which is causing a massive vacuum leak. After turing the vehicle off how many brake applications do you get before the pedal goes hard?
I'm betting only one.
Dragonmaster
« Reply #2 on: August 11, 2005, 09:47:39 PM »
I'll second what Clay said, probably a bad brake booster.
