Author Topic: Super noob question  (Read 1025 times)
Offline McClare
Super noob question
« on: June 18, 2007, 11:04:27 PM »
If someone is selling 3" leaf springs does that mean it will add 3 inches lift? Also, would said leaf springs from an XJ fit on a comanche and give the 3" lift even though it is spring under axle?
1992 MJ, 3" skyjacker, 31" BFG MT, Rollbar
Re: Super noob question
« Reply #1 on: June 19, 2007, 07:10:44 AM »
Quote from: "McClare"
Yes when someone posts 3" leaf springs that is 3" lift.  Now about the XJ leafs into a MJ, not necessarily because it all depends on the MJs original spring arch.  XJs are pretty flat from the factory.  I would say you might end up with a slightly lift 1-1.5" but not 3"
Offline rws
  • Stump Grinder
Super noob question
« Reply #2 on: June 19, 2007, 09:13:30 AM »
The MJ  main spring is longer than the XJ main spring.    The easy solution is to get a custom leaf pack built by a spring company.  As mentioned above the "mix and match" will not result in 3" of lift.
Super noob question
« Reply #3 on: June 19, 2007, 09:33:04 AM »
MJs springs go under the axle where as XJs go on top of the axle, which is why MJ spings have more arch. For an easy 5-6" of lift on the back of an MJ simply cut off the spring perches and re-weld them on top of the axle(spring over).
And as said the main leaf on a MJ is longer than on an XJ.
Offline McClare
Super noob question
« Reply #4 on: June 19, 2007, 07:22:57 PM »
I went into standens to see if they could make some custom springs but the most they said they could do would be about 1.5" lift. If I do a spring over, it'll cost way more than I can afford right now because of all the extra parts to make it work right without vibrations and messing everything up. Plus I already have all the parts for a 3" lift in the front and the rear of the kit really did nothing for me
Offline McClare
Super noob question
« Reply #5 on: June 19, 2007, 08:04:40 PM »
A lot of kits I've looked at just have shocks and an add-a-leaf in the back. How would the add-a-leaf give 3 inches?
Offline rws
  • Stump Grinder
Super noob question
« Reply #6 on: June 20, 2007, 08:41:16 AM »
Go to Standons and get the a new leaf pack arced up 1.5 '' than insert the 3'' add-a-leaf which will result in close to 3" of lift.  If you add a 3" add-a-leaf to a set of tired old springs they will very quickly settle down to "very little" lift.
