Author Topic: Violent shake  (Read 1107 times)
Offline McClare
Violent shake
« on: June 24, 2007, 10:19:01 PM »
I put a 3" skyjacker lift on a 92 MJ yesterday that consisted of coil springs, shocks, track bar drop bracket, and control arms for the front. When driving straight, the steering wheel is rotated 90* clockwise and the truck pulls slightly right. When I was driving on the deerfoot the front end started shaking violently. It felt like I was driving over moguls. I wasn't able to get an alignment on a sunday so I still have to do that but I doubt that was the problem with the shaking. I'm guessing the pitman arm has to drop lower but I'm not 100% on that.
And what places will do the alignments? I doubt that most places will do them with aftermarket parts. The first places I'll call is national and modern motors.
1992 MJ, 3" skyjacker, 31" BFG MT, Rollbar
Violent shake
« Reply #1 on: June 24, 2007, 10:28:40 PM »
scroll down or search for death wobble.  google too.  there have been a few posts on it recently.
Offline McClare
Violent shake
« Reply #2 on: June 24, 2007, 10:30:08 PM »
ok thanks
Violent shake
« Reply #3 on: June 24, 2007, 10:59:52 PM »
for alignments we use harpers or kal tire on mcleod. make sure you ask them to inspect the suspesion components before they align it. and be sure that the trac-bar nuts and bolts are all tight.
Offline XJwrencher
  • Pavement Princess
Violent shake
« Reply #4 on: June 25, 2007, 01:35:58 AM »
I'd try a beefer steering dampner/shock just a thought tho
94 XJ with tires and sausage to make it go off roading
Offline rws
  • Stump Grinder
Violent shake
« Reply #5 on: June 25, 2007, 09:01:00 AM »
Same thing happened to mine.  Rode perfect after agjusting the toe-in.
Offline McClare
Violent shake
« Reply #6 on: June 28, 2007, 10:33:31 PM »
Just going to let everyone know that I took it to kal-tire and they did the alignment and it fixed the problem 100%. No modifications had to be done. Hopefully this helps someone in the future
