Author Topic: TJ idle surge 2.5L  (Read 935 times)
Offline RedApe
    • http://www.island4x4.com
TJ idle surge 2.5L
« on: July 12, 2007, 09:54:12 PM »
Hi guys,
So, this one is starting to get annoying. 97 TJ, 2.5L
Symptoms:
Idle surge is not quite accurate, really.  At true idle, there is little to no surging.
It's most noticeable at launch, off the light/from a stop. 2-4 obvious surges in rpm before coming into power.
I'm almost sure it's a sensor, just need an idea of which I should replace first.
Has anyone seen this/have idears?
Did a board search, and Googled till the Hummer's came home... :lol:  :wink:
TIA,
Keith <aka RedApe>
94 XJ <his>
97 TJ <hers>
Four Wheel Stampeders member
lugnut8
TJ idle surge 2.5L
« Reply #1 on: July 13, 2007, 09:56:51 AM »
Same thing is happening on my 2.5L, but much worse. So far I have Replaced the rotor, cap, plugs and wires, AND the TPS. But the problem is still there, just a little milder.
So she is going in for a diganostics test on monday. Ill let you know what they come up with. :x
Offline EVOLUTION
    • EMF Rod Ends Website
TJ idle surge 2.5L
« Reply #2 on: July 13, 2007, 10:14:54 AM »
Any idle problems I've had with my TJ were always because of the TPS or an oxygen sensor.  It's a $40-$60 part...   dont know if this helps, but it wouldn't hurt to check them out.  Even just cleaning them can sometimes work.
Good luck!   8)
Evolution Machining & Fabrication  403.935.3540
Evo Forums:  http://www.evolutionmachining.com
Evo Joints website:  http://www.emfrodends.com
Facebook Page:  http://www.facebook.com/EMFRodEnds
Offline RedApe
TJ idle surge 2.5L
« Reply #3 on: July 15, 2007, 01:22:57 PM »
Thanks for the input....
I've already done an O2 sensor....TPS will be next on my list as well.
Keith <aka RedApe>
94 XJ <his>
97 TJ <hers>
Offline RedApe
TJ idle surge 2.5L
« Reply #4 on: September 23, 2007, 09:17:54 AM »
Just to update on this....TPS resolved ALL symptoms. Thanks for the feedback!
Keith <aka RedApe>
94 XJ <his>
97 TJ <hers>
