Author Topic: Transmission Trouble  (Read 1598 times)
2360
« on: August 18, 2007, 11:44:09 PM »
I'm hoping someone could tell me how much time the shop manual say's it takes to re + re a transmission in a 88 Jeep Commanche.
I had a shop in Calgary put in a used transmission in but it had problems, I took it back next day and they agreed it needed to be changed.
I think I'm getting ripped off, the total bill is around $2400.
Any info would be helpful,
Offline rws
  • Stump Grinder
« Reply #1 on: August 19, 2007, 09:42:07 AM »
Does that include rebuilding?  Is it standard or auto, either way $2400 to R&R equates to 24 hours of shop time.  I would call a few rebuilders and get some quotes.
2360
« Reply #2 on: August 19, 2007, 09:47:34 AM »
It was just a swap with another used transmission.
It,s a standard, BA 10/5.
Offline bae146
Mitchel
« Reply #3 on: August 20, 2007, 04:36:29 PM »
Mitchell on demand lists the hours to remove and replace that transmission at 5.1 hours.  the BA transmission is only good for a boat anchor.  You should be swapping a different transmission into that vehicle.  If you have a 4cyl you could put an AX 5 or with a 6 cyl an AX 15.  What shop are you using?
2360
« Reply #4 on: August 20, 2007, 06:00:58 PM »
Thanks for that info.   A relative got me in contact with someone today who said Cheltons (sp) says it takes 2.3 hrs to re+re the transmission.
I took it to "The Transmission Specialist" here in Calgary. I'm having quite a time with them.   It took them about two months to do the job and the hassel isn't over yet.
I went to the BBB and AMVIC.   Not much the BBB could do, so that's just leaves AMVIC or going to court.
As for a different transmission, I gave it quick thought but I doubt the Jeep will be in there for the long run.
Offline XJwrencher
  • Pavement Princess
« Reply #5 on: August 20, 2007, 07:27:27 PM »
that the shop down on macleod tr on the way to shawnassy?
94 XJ with tires and sausage to make it go off roading
2360
« Reply #6 on: August 20, 2007, 09:05:04 PM »
Offline XJwrencher
  • Pavement Princess
« Reply #7 on: August 20, 2007, 09:34:28 PM »
ya the shop i used to work at had quite the fight with them, but 2400 sounds just wrong for a R&R of a standard trans.
2360
« Reply #8 on: August 20, 2007, 11:54:12 PM »
That's interesting, what was the fight over?
I hope it turned out well, but it's difflicult when they aren't truthful.
