Author Topic: 4.2L/4L sudden appetite for oil ...  (Read 1474 times)
yjcanibul
« on: August 26, 2007, 10:16:29 PM »
puzzled by the sudden appetite for oil ...  any idea's ?
4.2L block with about 180,000K with 4L HO rebuilt head with about 50,000K and MPI ... no leaks ...
usually use about 1L oil between changes (3000km), used 2.5L this time ?
checked compression and dry they are all between 120psi to 130psi ,  plugs look fine with gray ends - no deposits ...
Offline big black dodge
« Reply #1 on: August 27, 2007, 08:52:27 AM »
could be your rear main - the oil is just collecting on the tranny
81 CJ7 350, SM 465, Dana 300,  dual dana 44, 4" lift, soon 33" TSL
yjcanibul
« Reply #2 on: August 27, 2007, 09:47:10 PM »
not a drop leaks anywhere on this jeep ... wouldnt it just seep out where the bell housing meets block ...
what ever's gone wrong it happened quick not gradual , the tail pipe is black/soot like and feels a little greasy ... and a light smell of eng oil in the air so its burning it ...
I dont think its economical for me to buy the stuff todo a leak down test, anyone recommend someone in the N.W. who could do ... the compression test only verifies the rings and I think the leakdown can pinpoint something in the top end (int/ex etc) ....
Offline XJwrencher
  • Pavement Princess
« Reply #3 on: August 28, 2007, 12:43:50 AM »
Try checking the air box to see if has oil in it,could be lots of blowby just a thought.
94 XJ with tires and sausage to make it go off roading
Offline rws
  • Stump Grinder
« Reply #4 on: August 28, 2007, 09:13:38 AM »
Checking the airbox is a good idea.  The CV valve at the back of the valve cover can plug very suddenly forcing oil thru the front hose onto the air filter.
yjcanibul
« Reply #5 on: August 28, 2007, 09:52:37 AM »
ok thanks all ,  I will check my ccv , I knew a plugged pcv valve could do this as its mechanical and could stick but when I converted to mpi I noticed the ccv was just a hole (oriface) in the hard plastic and figured it would never clog... let me check that asap ...
yjcanibul
« Reply #6 on: August 28, 2007, 01:17:34 PM »
ccv device and tube etc all clear ... even put some air in the fitting on intake and it escapes out throttle body ... noblockage ...
« Reply #7 on: August 28, 2007, 07:39:50 PM »
it may be a longshot but possibly the valve guides are leaking oil into the cylinders. pull the intake and you shoul see a lot of crud all over the intake/exhaust valves.
good luck:)
yjcanibul
« Reply #8 on: August 28, 2007, 09:22:09 PM »
short of pulling the head will take it apart this weekend, picking up some valve stem seals from NAPA and plan to replace them while in there unless I find something obvious ....
thanks ...
yjcanibul
« Reply #9 on: September 04, 2007, 10:31:13 PM »
NAPA had trouble getting the stem seals by friday so went with mopar , did them on the weekend,  at least 3 appeared to be leaking inside , the ones I pulled seemed like a cheap design with just a metal band around rubber whereas the mopar design has a metal lower case and a tiny spring tensioner at the top ...
so cranked it up this evening and first thing I notice is no stench of burning oil, took it for a short drive and no stink coming in the back window so think I got it  :lol: ...
true test will be pulling the dip stick after the first tank thru but things are looking good ...
