Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
XJ barely starting...
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: XJ barely starting... (Read 1742 times)
dubbleJs
Talks waaay too much!
on:
September 19, 2007, 08:37:33 PM »
Over the past while my 91 XJ has been starting a little weaker and now it barely starts. I tested my battery and it came out fine, Im now leaning towards maybe a bad starter.
Anyone have any other ideas or had a similar problem?
Logged
'91 XJ - 3" procrap - cutout for 33" MT's - More and more dents every run...Sold.
RckyMtnTJ
UberWheeler
Reply #1 on:
September 19, 2007, 10:38:48 PM »
Sounds like my TJ. It was doing the same thing. It finally went on July long so I replaced it with a rebuilt that I had with me. It worked great for a few days. Now it has gotten deathly slow. I am assuming either a bad electrical connection at the starter or a bad rebuild. Definitely interested in what you find.
Logged
98 TJ 4" lift + goodies
dubbleJs
Reply #2 on:
September 19, 2007, 11:20:39 PM »
thanks for the info. Im hoping to figure it out asap, might just head to the junkyard this weekend and get a cheap used starter and hope it works alright...need the Xj back on the road soon its my DD right now!
Logged
Dragonmaster
Guest
Reply #3 on:
September 20, 2007, 02:37:33 PM »
Might be bad battery/starter wiring. If the wire has corroded inside the casing it can cause similar symptoms leading to weak current or an intermittent connection due to too high of a resistance in the wires.
Did you actually have the battery load tested? I have a feeling the battery might be toast also.
Logged
dubbleJs
Reply #4 on:
September 20, 2007, 11:23:11 PM »
Yea I just took it to Crappy tire and had them test it, they said it came out fine. It started doing this with one battery then I got another one off a buddy who charged it up for me and it does the same thing...
Logged
rws
CJA Members
Stump Grinder
Reply #5 on:
September 21, 2007, 08:16:07 AM »
Check the resistance in your battery cables and clean the ground connections on your engine block by taking them right off and polishing them with a wire brush. Some people run a second ground cable from the battery neg. post straight to the frame. Could also be your starter relay but unlikely.
Logged
dubbleJs
Reply #6 on:
September 24, 2007, 10:39:00 PM »
Thanks for all the suggestions, looks like rws won this one.. everything just needed a brush and a clean up!
I disconnected the starter wires and battery ground to motor and cleaned them all with a wire brush. Brushed the terminals in the dizzy cap a bit, cleaned some dust and crap out of the starter relay sockets...and after a couple clicks from my almost dead battery..it fired right up! Seems to be all good so far.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
