Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Gears for 1989 YJ
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Gears for 1989 YJ (Read 947 times)
jtmtetat
Guest
Gears for 1989 YJ
on:
September 25, 2007, 11:34:52 AM »
I've got an 89 YJ 4.2l. I really have no idea what the gearing is other than it is desperately high sped. I am looking at doing the gears and adding lockers. My question: is there an easy way to find out what mine has for gears, axles (C clip or Non C clip). I would like to go to 4.56's and have a line on some good deals out of the states. I website I was on stated that if the existing gears were smaller than 3.54's and I wanted to go to something bigger than 3.73's than I would have to change the casing. Do they mean carrier?
All help and advice is appreciated.
Logged
redbull
UberWheeler
Re: Gears for 1989 YJ
Reply #1 on:
September 25, 2007, 12:22:35 PM »
Gear ratio should be stamped on a metal tag held on by the diff cover bolts. If it's too rusted or lost, you can jack up the rear, spin the tires once and count the number of revolutions the drive shaft does.
Your 6 cylinder YJ is likely 3.07 gears.
Logged
cLAY
Talks waaay too much!
Gears for 1989 YJ
Reply #2 on:
September 25, 2007, 12:28:44 PM »
If you are going to use a full locker like Detroit or ARB, it replaces the carrier. The "lunch box" lockers need an "open"(non-posi) carrier to be installed into.
Logged
Bnine
Sticky Fingers
Gears for 1989 YJ
Reply #3 on:
September 25, 2007, 12:38:08 PM »
Look in the for sale section at 4wheelr.ca
There is a complete 8.8 with a detroit, and gear options of 4.10, or 4.56.
All for less then you will spend on new parts for that 35 you have.
Plus an 8.8 is at least twice as strong.
Logged
[email protected]
padler
Baby Wheeler
Gears for 1989 YJ
Reply #4 on:
September 25, 2007, 09:46:21 PM »
yeah thats my axle i'm looking to sell,
for 8.8 31 spline disc brakes assie locker 4;10 gears. pretty much a direct bolt in.
i found that the gears with my tires are pretty much perfect. only reason i'm selling is im goning much bigger.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Gears for 1989 YJ
