Author Topic: Jeep yj e-brake  (Read 1256 times)
Offline bae146
Jeep yj e-brake
« on: October 08, 2007, 08:58:28 PM »
So my yj's useless e-brake is no longer holding, the lock no longer holds the brake engaged.  Has anyone come up with a replacment idea?  The factory's offering in this department is sadly lacking reliability.  I know there was a recall on this item a few years ago and this one has been replaced under the recall but it is dead again.  Anyone got any ideas?
Offline apex
Jeep yj e-brake
« Reply #1 on: October 08, 2007, 10:34:55 PM »
empty beer bottle should do the trick.
Hold on, maybe that isn't a good idea.
Jeep yj e-brake
« Reply #2 on: October 09, 2007, 09:23:11 AM »
I am in the same boat.  I had to buy a new one earlier this year and it is already acting up.  It is brutal.  I even sent a compliant to Jeep about the quality of parts.  I am on my 4th pedal assembly.
One option would be to convert to a pinion style brake on the t-case output shaft.  I know you can do it on yota t-cases
Offline bae146
t case
« Reply #3 on: October 09, 2007, 11:52:07 AM »
One of the guys on the stampeder's site has a disk on the output of his transfer case.  However with 33" tires he says the leverage is to great and the jeep still will creep with the brake on.  I know princess auto has a bus e-brake lever maybe I will have to buy one and see id I could rig something up?  Where are you getting you e-brake brackets from, I should get another one in the interim while i figure out a real fix...
Offline Gearhead
Jeep yj e-brake
« Reply #4 on: October 09, 2007, 07:06:44 PM »
I've had my 94 YJ for just over two years now , it was from BC , needed an out of province inspection . I ran the V.I.N. thru Chryslers online recall / checker ?  and figured if there were any outstanding recalls , I'd have em done. The park brake recall was all that needed to be done , at that time there was nothing wrong with the way the park brake worked on the 94 , the 88 needed repair but had no recalls. Thinking a recall must be an upgrade , I went ahead and had it done.
The assembly they installed looked to be a better part , had an additional brace , all seemed good.  Within six months it had self destructed. The original had lasted eleven years and still worked when the recall was done.  I fixed it , had to weld a cross pin / pivot , it's still holding.
My 88 had issues with wear on the ratchet and would release without warning , that one got replaced with a used part from Jeep stuff.
Jeep yj e-brake
« Reply #5 on: October 10, 2007, 07:59:58 AM »
it may be a lot of work but... a slick trick is to run two pull handle type e-brakes so you can control each rear wheel. measure out a couple different cables and see if they will reach to the handles... wherever you mount them. and the neet part is if you have a selectable locker you can dis-engage it and then pull one e-brake and turn on a dime. i think i read it in a mag a while back. just a thought.
