Author Topic: Rim backspacing  (Read 966 times)
gcam
Rim backspacing
« on: November 08, 2007, 01:32:42 PM »
Do all Jeep factory rims have the same backspacing? If I were to swap on a set of Rubicon rims to my XJ, would I gain a little wider stance? thanks
Geoff
Re: Rim backspacing
« Reply #1 on: November 08, 2007, 02:03:24 PM »
Quote from: "gcam"
Geoff
Backspacing and stance is dependent on rim width.  I believe most Jeeps rims were around the same BS but there are a mix of 7" and 8" wide rims.  Now if you are swapping to a rubi rim (16x8) from one of the stock XJ rims (probably 15x7), you might gain a little in stance width
Dragonmaster
Rim backspacing
« Reply #2 on: November 08, 2007, 04:08:51 PM »
Stock BS is 4.5" I believe the rubi's are 4" BS.  And as stated the width of the rim will come into play also.
dlarrivee
Rim backspacing
« Reply #3 on: November 08, 2007, 06:37:46 PM »
Quote from: "Dragonmaster"
More like 5.25" on my XJ.
04_RME
Rim backspacing
« Reply #4 on: November 08, 2007, 06:53:23 PM »
The rubicon rims have 5" backspacing, and most tj's had 5.5" backspacing, not sure what the cherokees had for b/s
