Author Topic: Air bag light is on?  (Read 1453 times)
Offline 01sahara
« on: November 22, 2007, 10:01:46 AM »
Hey.
In the vast pile of Chrysler / Jeep knowledge on this forum I was hoping someone might have the answerer to a tech question I am working through.
Problem, the air bag light on the dash is on. Why , because I did not disconnect the battery, as I should have, while I was disassembling interior components to replace the blower  switch and blower resistor. My mistake.
While I was removing stuff I took the consol out and disconnected the On/Off switch for the passenger side air bag in my 2001- Sahara. That is when the light came on.  The switch is now hooked back up but the light has not gone out. I tried taking the positive terminal off the battery to reset things but that did not work.  Is there a way to reset things so the light goes out? Do I need to have a code reader to clear the system?
Any advice would be appreciated.
Thanks,
Blair
Offline Mudhawg
  • Rig Life
« Reply #1 on: November 22, 2007, 10:04:24 AM »
smack the dash??? i know Av9inch's jeep does it with the airbag and check engine light u give the dash above the cluster a smack and it goes away
Offline 01sahara
« Reply #2 on: November 22, 2007, 10:15:04 AM »
Quote from: "Mudhawg"
Thanks Doug, I new it would not take long to get the real hi-tech solution to the problem. :lol: . I won’t rule out your choice but are there any other suggestions. Or would someone like to suggest the weight of the hammer I should use to smack it with.  :wink:
Offline AV.NINE
« Reply #3 on: November 22, 2007, 10:21:15 AM »
Little different, I didnt disconnect anything, and when mine comes on all my gauges stop working..... but then a good smack, and shes all good.
« Reply #4 on: November 22, 2007, 10:54:01 AM »
Check the fuses, turn the switch back and forth, lastly try a comp reset.
Comes back , look for codes.
Offline XJwrencher
  • Pavement Princess
« Reply #5 on: November 22, 2007, 11:07:51 PM »
Does the horn and/or cruise control still work?
94 XJ with tires and sausage to make it go off roading
Offline 01sahara
« Reply #6 on: November 23, 2007, 09:03:51 AM »
Quote from: "XJwrencher"
I think so? I will have to try the horn.
« Reply #7 on: November 23, 2007, 10:42:48 AM »
Quote from: "01sahara"
Think French... start swearing, give the finger to every other people that passes you, honk at the world and drive with your knee.
Offline 01sahara
« Reply #8 on: November 23, 2007, 10:52:58 AM »
Quote from: "SwampSinger"
I don’t think I have hit the horn in the last month.
Either I am being to nice or I should start giving people warning before I drive over them.
