Author Topic: body lift?  (Read 1049 times)
Tip Over Ter
body lift?
« on: December 09, 2007, 10:03:23 AM »
Hi everyone, I havn't been here in a long time but I figured I would ask the PRO'S  :lol: . I would like to install a bodylift I got from ebay. The kit only comes with spacer blocks and longer hardware. The only things I can think of is I have to trim my fan shrowed but what about my sifters inside the cab and is there anything eles that I need to be aware of?
So thanks for your input and keep the rubber side down
Terry
Offline calltrex
body lift?
« Reply #1 on: December 09, 2007, 10:15:42 AM »
might need the skyjacker shifter relocator or your shifter may pop out all the time
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline NS-jeeper
body lift?
« Reply #2 on: December 09, 2007, 04:08:57 PM »
depends on how big the body lift is I would think?
Offline cablesmurf
  • Relapsed Jeep Addict
body lift?
« Reply #3 on: December 09, 2007, 04:13:21 PM »
Quote from: "calltrex"
I have one you can have for free if you need it.
Hi, my name is Dan and I'm a Jeepaholic
body lift?
« Reply #4 on: December 11, 2007, 11:24:33 PM »
What size body lift?
You need to relocate the shroud, as well as do some trimming along the lower corner where the rad hose exits.
Relocating the rad itself, or doing a motor mount lift in conjunction with the body lift are both better methods of getting stuff lined up right.
You also need extended front snubbers, and potentially a t-case shift bracket.
With brand new complete body lifts costing 85$, I cant imagine a partially complete ebay BL being worth it.
I have all the spare parts for about 3 complete body lifts. Let me know if you are missing anything. We can dig something up for ya.
Offline TrappersJeep
body lift?
« Reply #5 on: December 12, 2007, 11:30:43 AM »
Chances are you'll need to extend your fuel filler line as well.  Not sure what you're putting the lift into or how much lift but chances are the original hose will be a tad short once lifted.
RIDER PRIDE IS OUTTA CONTROL!!  CRACK THE PIL AND BRING ON THE CUP!!!
Offline AV.NINE
body lift?
« Reply #6 on: December 12, 2007, 11:39:09 AM »
Quote from: "TrappersJeep"
Lol, i had that problem in my first yj. Could figure out why i was spending so much at the gas station ;)
Tip Over Ter
body lift?
« Reply #7 on: December 12, 2007, 02:23:35 PM »
sorry guys, its a 2" lift going into my 05 rubi dose everything said in the above post still apply?
