Author Topic: biggest tire on stock 98 Grand Cherokee Laredo  (Read 1040 times)
drush
« on: December 10, 2007, 09:25:43 PM »
Just wondering what the largest tire is that I should install on a stock 1998 Jeep Grand Cherokee Laredo , 4.0 L , Auto.
« Reply #1 on: December 10, 2007, 10:31:30 PM »
that depends on how much rubbing you can live with... generally speaking, you can go up one size from stock. and thats on stock oem offset wheels.
Offline Mudpig97
« Reply #2 on: December 11, 2007, 10:25:20 PM »
85 CJ7, toy axles and 35's, miller locker in rear.
Offline Mudpig97
« Reply #3 on: December 11, 2007, 10:26:43 PM »
My 97 came stock with 215/75R 15 but I have run  235/75R 15s before my lift with no problems.  31's will rub even with a 2" lift.
« Reply #4 on: December 12, 2007, 04:53:33 PM »
My dad has 30X9.5s on his stock '96 4.0. No rubbing but he doesn't wheel it hard.
I've got 31X10.5s on my '93 5.2 with the Upcounry package(factory 1" lift). They rub on the lower control arms at full turn. Not sure about offroad as I havn't taken it offroad yet, tires are toast.
Both are running stock rims.
« Reply #5 on: December 12, 2007, 07:16:11 PM »
Some rubbing offroad with 31's, but they do flex really good.  :D
Offline Mudpig97
« Reply #6 on: December 12, 2007, 09:07:34 PM »
I had to trim  the front bumper plastic to fit the 31's even with 1 3/4" spring spacers and I hit my fenders a couple times wheelin. Running 15x8 wheels with some offset so they stick out a bit though.
« Reply #7 on: December 16, 2007, 10:01:46 PM »
stock, i'd suggest 235s just as others have suggested. u can go bigger, just gotta cut what gets in the way :wink:
