Author Topic: A Test For You to Take!  (Read 1548 times)
Offline calltrex
« on: December 17, 2007, 12:17:52 AM »
Good Mechanic test
http://www.forddoctorsdts.com/quizzes/MechanicalAptitude.php
90% for me
guess i should have looked closer at some  :roll:
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
« Reply #1 on: December 17, 2007, 12:51:03 AM »
80%
pullies got meand a few others like wormgear
flyingphil
« Reply #2 on: December 17, 2007, 06:40:50 PM »
got 90%, what a bag drive.  Felt like I was in school all over again.
Phil :wink:
wrenchead99
« Reply #3 on: December 17, 2007, 07:34:27 PM »
98%.... :lol:
« Reply #4 on: December 17, 2007, 08:04:19 PM »
Yawn..
100%
Offline Rookie
« Reply #5 on: December 17, 2007, 08:18:08 PM »
92%  but I'm pretty sure I aced the electrical section    :D
TJ with some stuff
Offline redbull
« Reply #6 on: December 17, 2007, 09:58:10 PM »
I got 92% as well. Not bad if I do say so myself.
« Reply #7 on: December 19, 2007, 12:35:40 AM »
i got 86%... forgot some of the pulley stuff from school as well. except # 48 bugs me. maybe someones wants to add an opinion...
the air enters the cylinder on the intake stroke why? from atmospheric pressure or from the vacuum created by the piston lowering in the cylinder? the right answer sais atmospheric pressure... i say vacuum. in a sense both are right im thinking...
« Reply #8 on: December 19, 2007, 07:23:47 AM »
Quote from: "hps4evr"
Well it would depend if the exhaust valve is open or not.  If the exhaust valve is partially open, then the answer would be vacuum until the exhaust valve closes, then atm pressure.  If the exhaust valve is closed it is just atm pressure.
« Reply #9 on: December 20, 2007, 07:17:10 AM »
after some more thinking and chatting with others... it has been determined that i should go back to school, lol! ill think about it more i guess... either way, atmospheric pressure is ok, boost is better;)
